Cone type filter question
RE: Cone type filter question
Try either Forcewinder ( useforce.com ) or Doherty machine. they are both excelent breathers. May I also suggest aA aluminium carb/efi. bracket. mounts to the breather bolts in the heads and holds it all together. the breather holes ard directly in the throat of the mount. no need for any extra hoses or filters to muck up the looks of your ride. I used one on my Sportster, really clean look.
Screaming Eagle also do one, the Pro Heavy Breather, below is a link to a pic of one on my XL1200C
https://www.hdforums.com/albumtn.asp...h241343832.jpg
there are a few things you will need to make sure you get if you go with a forcewinder. you will also need to get a carb support bracket and also get a horseshoe breather kit. Its a great piece and you can't beat the looks of them. They actually perform better then most other intakes also. I would highly recommend it to anyone.
