DK coil relocate help
A couple of questions:
1. Are the 2 wires that plug into each of the 2 terminals on the coil interchangeable? 1 is pink and came off the lt. side (see pic mark L), and the other is white w/black stripe. I may have to extend the white one to reach?
2. Are the actual spark plug wires interchangeable also, or do they have to attach to the same part of the coil as original?
Also, the wire extension harness that came with the kit, are different colors than the pink and white. Does it matter? Can I only use 1 of those wires to extend the 1 white wire in the pic?
Hope this makes sense to you guys, I'm trying?
Thanks for any help,
jeff
jeff
