1999 Hugger fork length vs. Standard???
Doers anyone know know the actual lengths of Hugger front fork tubes vs. Standard? Ive searched but can't find any consistent answers? Standard fork tubes PN 45395-97, Hugger PN 45395-92. Im ready to buy some on eBay for my 1999 883 Hugger to raise it up to standard fork length...
Until someone comes up with the answer, your only safe way of proceeding is to check what model the tubes you're looking at are for, or use the correct part number you have above. You should also check an on-line parts website, as you will also probably need longer damper tubes as well.
The list they give should answer which models they fit? The link I gave you tells you the H-D model and code for each model, the Huggers being 'CE', which use tube #45395-92. Only the Sport uses a third tube, #45366-96, but the entire fork is different. All the other 1999 models for that year, codes CAM/CAP/CG/C, models XL1200, XL1200C, XL883, XL883C, use the tube #45395-97. That should let you select the longer tubes you want. If not then give us a link to one of those Ebay ads, so we can see it. Are you looking at new or secondhand ones? A Harley dealer should be able to supply correct new ones.
