Looks more like what I really need and cheap enough to be worth trying. How does it attach?
You need to drill a hole in the kickstand to bolt on. Again, I will try to take pics with the kickstand up so you can see the position of the extension.
Its held on with a single (allen or torx) bolt ? It does look like it's easier to grab
with your boot heel...
thanks,
T.
Yes - a single bolt. The sides come down at the mounting area sandwiching the kickstand so the extension is pretty sturdy. In the top view pic, you can't even see the kickstand so it was a bitch to find without an extension. Works for me. Good luck!
If there is anything I do not like about it is the other end of the bolt scrapes the ground (see pics with kickstand down) and damages the concrete where I park...but I guess that can be resolved if you position extension a little higher on the kickstand. But IMO it is properly positioned based on the curve of the kickstand.
