STILL HAS A COUGH
RE: STILL HAS A COUGH
ORIGINAL: 05883C
Alright guys.... The bike is an 05 883C and Has SEII pipes, stage 1 screamin eagle air cleaner kit, and a stage 1 jet kit but the bike is still having a case of the coughs while at idle and cracking the throttle or trying to take off quickly.
Any new suggestions??
ORIGINAL: 05883C
Where's the mixture screw on the CV carb? Anyone have a pic?
Cheers,
Marc
I know what you mean. I have a 1200C w/185 main, and 45 pilot. That solved 95% of the situation, but I still get the caugh every once in a while. I tried the mixture screw in a bunch of different # of turns, and even went up to a 46 pilot just to see if that made a difference. Nope. Still did it occasionally. Went back to the 45 pilot, and now am starting to think that there may be an issue in the accelerator pump circuit. I dont know. It seems to do after holding a continous part throttle position for an extended period of time, then go to crack the throttle.
I havent given up, but still trying to figure it out.
