BHG on iron 883 with 1200 kit
Old 03-14-2016, 05:46 PM
Matt87gt's Avatar
Matt87gt
Matt87gt is offline
2nd Gear
Unhappy BHG on iron 883 with 1200 kit
Hey
So I have a 2010 883n when I bought it it had already had the screaming eagle
1200 heads installed. Took her for a spin yesterday and upon stopping found some oily residue on my saddle bag. Found the source is from the head gasket.
I'm trying to figure out what gasket kit I would need for this since it's got different heads. Does anyone know if cometic makes a gasket kit?
Thanks in advance for any help.
Old 03-14-2016, 05:51 PM
Von_Zipper's Avatar
Von_Zipper
Von_Zipper is offline
Cometic makes kits, yes. Is your leak from rocker box gasket?
Old 03-14-2016, 07:54 PM
Matt87gt's Avatar
Matt87gt
Matt87gt is offline
2nd Gear
It's leaking from the rear head, between the head and the piston.
Old 03-15-2016, 06:09 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Be sure to check very carefully. When hot a tiny amount of oil can travel a long way. It's sneaky stuff and often comes from further away than it first appears! Clean up everything and check again after another ride, then repeat if you're unsure. It would be a shame to remove the head and find nothing, especially if it's actually the front head, or quite likely the breather to the air filter.
Old 03-16-2016, 11:37 AM
Matt87gt's Avatar
Matt87gt
Matt87gt is offline
2nd Gear
When I can get away from work long enough, I'm gonna do a compression test, not sure how I'll disable the fuel on it yet tho. I'm pretty positive it's blown though, as it's oily only from the head and back, and it's on the left side sitting on the bike so it's opposite from the air filter. She rode home fine, about 18 miles after I saw the spot, but pulling in the garage I heard a slight pop like a loose header. Checked the header bolts and they're fine. Oil is on the opposite side of the headers too.
Old 03-16-2016, 12:29 PM
grbrown's Avatar
grbrown
grbrown is offline
Matt, I'm still hoping that someone with an '86 will call by and answer the question on static timing!
Old 03-16-2016, 01:39 PM
Matt87gt's Avatar
Matt87gt
Matt87gt is offline
2nd Gear
Google has a world of info on that lol.
Old 03-16-2016, 02:00 PM
Matt87gt's Avatar
Matt87gt
Matt87gt is offline
2nd Gear
I was just thinking though, why would oil come out?
Old 03-16-2016, 02:11 PM
Matt87gt's Avatar
Matt87gt
Matt87gt is offline
2nd Gear
There's no oil passages between the head and the block is there? never mind dumb moment
roy_b
05-31-2017 10:55 AM
Nosoup4u
03-22-2017 08:18 AM
speedjerm
03-26-2016 01:31 PM
cripple
06-23-2013 07:04 PM
deltaoil
Exhaust System Topics
12-18-2006 11:50 AM
Quick Reply: BHG on iron 883 with 1200 kit
