I did a 1200 conversion need help
I just finished up my 2006 883 to a 1200 conversion earlier today I used the v-twin brand conversion kit as it was all I could afford anyway I got it all together and ride it down the road a little ways and it just doesn't seem to have much if at all any power difference I put a new 180 main jet and a 45 slow jet in and other then that haven't done anything elese so far waiting to get enough money to get the 1200 ignition but it pops a lot and backfires quite a bit when I let off the throttle also if anyone knows why theses problems are happening please let me know
I apologize ahead for my spelling and grammar
Once that's done you need to check for air leaks around the intake manifold and the exhaust system. Then it will be time to get the carb properly jetted.
What do you mean a stock 1200 ignition module? Just curious. (At this point) Which model did you order? Part number?
That is the same ignition module you already have. I'm pretty sure the 883 and the 1200 have the same part number module, and same part number crank trigger. Go look at the part number on your bike and see if you just ordered the same part.
32622-04C I believe. That is the new number for the replacements, but it is for both the 883 and 1200.
