FXDXT retro T-Sport Saddlebags on Sportster?
OK, a little more hope... here's where I am after measurements...
The measurement across the signal bar is 12". The measurement across the top of the fender where the mounts need to go, taking into account the sissy bar mounts which stick out from the strut 3/4", is 11 1/2".
Surely there must be 1/4" on each side that will be made up just by the mount bolts? The bag can't go completely up against the strut, right?
If you go back to post #19 in the link I gave above, you will see my photo of the mounting posts on my bike. They are the minimum length at the rear for the bags to clear things, once mounted. If you add clearance for your sissy bar you may have to move the bags a bit further away from the side of the bike, which brings us to one of Garry's photos, in post #11 of that same link. He shows the left bag with spacers for docking hardware. Ever closer?!
I do believe this is going to work just fine. Close yes but close is good.
This image, taken before the signals were relocated, shows how the sissy bar mounts to the same points where the bags mount. The sissy bar mounts stick out 3/4" from the strut so once I put the bag mounts on there I'll easily gain the needed extra 1/2". Agree?
Looking again at my post #19, each stock mount is made up of a long 3/8" dia screw, going through two separate spacers. The small diameter spacer carries the bag when installed, so is critical to the success of the installation. The inner larger OD spacer simply provides a shoulder against which the bag mount is located, also positions the bag so it clears other things on the bike.
So to complete your installation, you will need to fit the small spacers, but I suspect you will only need short large OD spacers, to provide the inner shoulder. That would indeed easily give you the extra 1/2" or so you need. I seem to recall that the bags come with a selection of spacers of different lengths and you may find all you need in the kit.
For various reasons already mentioned I ended up making my own inner spacers and didn't keep the remainder of the kit, so can't confirm that. Garry now provides additional spacers, for adjusting the front mount to improve clearance with a wide seat.
Hope that helps, having written while thinking out loud!
WVDevil (04-18-2016)
Bet he makes them one-off instead of keeping in stock?
My pleasure - it will be great for more than one of us to have a set! I got the impression they make small batches of them, so well worth contacting Garry to see if they have any in stock.
