RearWheel and Lower Fork Slider Swap
Thanks, very helpful....and more convincing to get a pro to do it. Sound like a do-able job, but need to buy the top cap socket and the plunger thingy to get the seal down seated firmly.
maybe a stupid question, but can you change the lower sliders without removing the entire slider and tube
The cap-nut socket and fork seal driver, with a plastic adapter for the lower top-caps, cost me about a hundred bucks. I've done multiple sets of Sportster forks, and the cap-nut socket fits the Big Twins I wrench on, so the tool expense isn't a big deal. Also, I believe that if you want something done right...
cvaria (04-28-2016)
My fork seal driver splits into two halves, permitting the devise to be used while fork tubes remain in the triple clamps. However, I find it easier to remove the fork tubes (after the damper screw has been removed from the bottom of the lowers, as previously mentioned). I bet you have a bunch of hardware on your tubes for the fairing, which, I do not.
Thanks all for the input. I will probably ask again the next time around..lol
neurostudy
01-28-2007 04:16 PM
