PCV used? Missing anything
I picked this up on Ebay for my 08 Sportster XL1200 R Roadster.
http://www.ebay.com/itm/222081094472...%3AMEBIDX%3AIT
I think it has everything id need from what I saw in the install pics. (pcv, connection cables, and o2 deletes)
Am I going to run into problems installing this?
if its new in the box you will have everything you need.....however it does say for 2009? did you get the part number for 2008? I just installed a pcv on my 2013. it connects into ECM, the coil, your knock sensor and data port you unplug your o2 senors and attach the opitmisters(caps) for the plug and the o2 senors just say unplugged. it also have a red/white wire (speed wire) that just taps into a wire. I did not install this, talked to my dyno guy he said i wasn't needed. I have been running a stock dyno jet tune with no issues. once i bring it into to be dynoed ill know if the speed wire is needed.
Part number for 08 roadster is the same as this - 15-002
Its not new, only has the pass through cable and the 2 o2 deletes if Im not mistaken, but I dont think the 08/09 have anything about the coil or knock sensor, or speed wire. Least not in the install diagram I saw, but these are parts that Im glad you bring up, maybe thats additional bits I might need?
Yup that's all I got for my 07 except for the manual and a disk for the computer, if you have those you should be good to go.
(I loaded the disk but never have used the computer to make any changes, mine came with a map from fuelmoto and I had it dyno tested and was told it was a good map and to leave it alone so I did).
