Brake light question
Be sure to practice. Remember, tin the iron with solder. Twist the wires together.. Heat the wire and draw the solder to the iron. You will see it wick in. Few joints and you will be an expert...And your connections will take you to the moon and back. Rather then those crimp and junk connectors that flicker or quit working after the first year.
