Brake light question
OK so I have been doing some research and staring at the wiring diagram between my 883l and a 883 iron. My questionumber is I want to delete the rear center brake light of the fender and have just the 2 bullet lights like an iron had. Going to chop my fender and do some other odds and ends. How would I go about doing the wiring on this?
I guess to expand on this a bit. In your tail light (assuming it's wired the same as my 2006) you can just throw out the circuit board. You will have a ground wire right and left turn wire a brake wire and two running light wires. One of the running light wires is for foreign models. Just direct wire each turn signal wire to the appropriate side zip tie the rest up and hide them out of the way. Install module and good to go.
Wrong...it's not that easy, with a single filament bulb you could turn the signals into brake lights but then you would have no running lights on the back or signals. The purpose of the run/stop/turn module allows a single filament bulb to run at 50% power as a running light and 100% power as a brake/turn light, it also stops one side from being a brake light when activated as a signal. There is no way of doing that with just simple cut/strip/soldering as you say.
so this thread started and went no where... does anyone have pics of what they did or better advice on how to get these turn signals wired up. I'm using the module already but having trouble with where to wire them. i have an 06 with the 6 pin connector from the rear brake light. trying to get rid of the rear brake light and just use the turns
