Always have to choke it....
My '05 1200c (12k miles) won't start with choking it and it takes quite a while to warm up. This, in 60-70 degree temperatures. So I'm thinking the carb needs cleaning, at the least. New plugs and battery didn't change anything. It had straight-shots on it when I got it and I took them off and put stock pipes on. Wonder if it's a jet problem.
You might try some Seafoam in your gas. It cleaned the boogers out of my carb and I use a little on a regular basis as a fuel stabilizer.
I'm about ready to open mine up, I guess 25 years is a little overdue. But, she runs so well, it's hard to want to mess with it. I got a carb kit for under $20 as posted above.
BTW, the carb screws are JIS head, not Phillips head. Be careful not to strip them if you use a Phillips driver. I even got a JIS driver for when it's time.
John
John
John
John
I've got an '06 1200L and yeah - you got to choke it to start. and I've got to leave the choke pulled about half way for at least a few miles unless its hot out. It got a little worse when I did my stage one a few years ago. I put in a set of 118W TTI's and that helped alot, runs better too. Thats with a rejet, K&N, and 2" Rush slip-ons.
