Help with trouble codes
Hello guys, it's been awhile since I've posted here, so first.. Hello to everybody, I hope you're all doing well.
I'm throwing the following three trouble codes, and the battery & engine lights are on. I was sort of hoping the lights indicated the voltage regulator was going out because it already has once and I didn't know any better than to put back the stock replacement part.. I feel like it's a time bomb. The only work I've done recently is changing the battery and installing an LED headlight I got from DK customs. I haven't tested the battery, but it is still starting the bike, if a little slow.. I feel like the battery is a symptom, not a cause. I guess my first move is to disconnect that headlight bulb and take a ride to see if it resolves, but I thought I'd ask in case those line overvoltage codes indicated something common that I don't know about.
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
P0562 Battery Voltage Low
Received 2,189 Likes
also wouldn't hurt to check your connections. make sure everything that came off the battery went back on it.
Your codes do indicate a possible charging system problem. The fact that you have 2 codes indicating over-voltage points to the regulator, the other (P0562) can be indicative of either a stator or regulator.
The first step is to get the bike started and running at a high idle (~2,000 RPM) and use a digital voltmeter to check the battery voltage, either across the battery terminals or from the positive terminal and ground.
You should have something between 13.8 VDC and 14.8 VDC. Any higher or lower is a problem. Once that's checked we can go from there.
After tightening the connections on the battery, the codes went away, except for PO562 (low battery voltage), but the voltage at the battery while running is only at 11.6 (tached up a bit, I don't have an actual tach). The battery is at 12v when not running. Does this indicate a problem or does it just read low until the bike runs enough to charge the battery a bit?
Next step is to disconnect the stator plug and measure the stator output with the motor running. This is an AC voltage that should start out around 20VAC and climb upwards as the RPM is increased. It will go over 60 VAC if you rev it into the 4000-5000 RPM range.
Harley stators on the Sporty are well known for burning out, I had 2 fail in less than 50,000 miles. If your stator is bad, I highly recommend replacing it with one from Cycle Electric, they are much better made and more reliable. I installed one 60,000+ miles ago after the 2nd HD stator failure and have no more problems. The Cycle Electric regulators are also light years ahead on the old tech used in the HD regulators.
Harley (shunt type) regulators keep the stator running at 100% output whether needed or not and dump the excess current to ground. This makes for a lot of excess heat at the stator. CE regulators are of the electronic switching type and turn on/off as needed letting the stator run cooler and under less load.
