Rear axle nut size
Rear axle nut size
2011 Sportster Low XL1200L
I am prepping to get things ready (making sure I have all of the necessary tools) to replace my rotor and relocate the caliper this weekend. I need to remove the rear axle nut but don't have a sock that fits. I tried a 35mm socket and it appears to large since it has slight play. I have an adjustable wrench but that does not allow me to torque the nut to spec. I measure the nut and it is about 1 1/2". Axle size is 25mm.
And just in case you are wondering....I have a manual. There is nothing about rear axle nut size in it.
Thanks
Thanks
Thanks
Thanks
hscic (05-28-2016)
Received 2,189 Likes
I just changed the rear tires on my 2015 Iron 883 and it took a 36mm on the left and a 28mm on the right. I don't think it changed from 2011 until now. I'd check your socket again to be sure. I know somebody said they used a 1 1/4 inch on their 2011 72 when I was searching.
you friend:
http://www.harborfreight.com/6-in-di...per-61585.html
hscic (05-28-2016)
36mm, on the large side with the emergency clip. i used vice grips on the other side just to keep the axle from moving, which it didn't.
you friend:
you friend:
Jason Overdorff (04-25-2020)
okay now that I got the axle nut size as 32mm.
Anyone now the torque spec on a 2011 XL1200L...my manual says 95-105 ft lbs. Is this right? Just seems rather high.
Earlier models are 72-78 ft lbs but I believe had different type of bearings and would lock up if torque too much.
cvaria (05-31-2016)
