Allen Head Socket Size - 2009 Iron
Old 06-25-2016, 10:20 PM
CrackHeadBob's Avatar
CrackHeadBob
CrackHeadBob is offline
Default Allen Head Socket Size - 2009 Iron
I've tried searching here in the forum, on YouTube, on Google, and in the FSM. I'm trying to swap out my pipes, and I need remove the pulley cover, so that I can remove the crossover pipe, and install the bracket. There are three bolts holding it on. I have the two smaller ones out, but I need to go in the morning and buy a socket to get the third one out. (The larger one to the rear.) Can one of you fine folks tell me what size allen head socket I need to buy?
Thanks!
Old 06-25-2016, 11:38 PM
hscic's Avatar
hscic
hscic is offline
Not sure if 2009 Iron is the same as my XL1200L....if it is the larger one on the pulley cover holding the rear exhaust bracket, mine is an #8 allen
CrackHeadBob (06-26-2016)
Old 06-26-2016, 12:16 AM
Troops141's Avatar
Troops141
Troops141 is offline
Not sure on the size, but I was able to get a set from home depot for $10-15 that had 10 or so sockets. The set had all the heads needed for the job.
Old 06-26-2016, 08:42 AM
CrackHeadBob
Awesome! Thank you fine gentlemen for your assistance.
Later!
Old 06-26-2016, 08:55 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Definitely get a set...std & metric...you'll use/need them.
Old 06-26-2016, 02:28 PM
CrackHeadBob
Thanks again all for the excellent advice. I have a Harbor Freight close by, so I dropped in and got a set of metric and SAE, and a set of Torx bits, along with a few other things that fell into the cart. (That seems to happen a LOT a Harbor Freight....LOLOL)
The bit required for the bolt in question was a 5/16". New pipes are now installed, and fuel remapping is done.
I'll post up a pic later. Thanks again!
Old 06-26-2016, 02:38 PM
CrackHeadBob
Here's the way it used to look.....
Here's ow the pipes look now....
It also has black Progressive shocks, but you've seen plenty of pics of that.
Later!
Old 06-27-2016, 12:33 AM
Troops141's Avatar
Troops141
Looks nice
Old 06-27-2016, 03:46 PM
CrackHeadBob
Thanks. However, when I ran the bike, the orange burned out, and is now a sickly brown. I have some titanium on order, and the orange will be replaced. You can see it on the pics I uploaded to Amazon with my 1 star review:
https://www.amazon.com/review/R2JDGJ..._rv_eml_rv0_rv
Later!
dustyinohio
12-01-2013 10:33 PM
harleybiker
06-18-2011 08:35 PM
SgtMic
04-16-2010 09:11 PM
jackinthebox
01-10-2009 04:19 PM
Goldendyna
05-13-2008 10:52 AM
Quick Reply: Allen Head Socket Size - 2009 Iron
