Do I have a Starter or Battery issue
Old 06-27-2016, 08:41 PM
Steven Carr's Avatar
Steven Carr
Steven Carr is offline
Stage III
Default Do I have a Starter or Battery issue
Hi! I'm new to here. I picked up a 2008 Sporty 1200 Nightster. I have V&H Short shorts and Stage 1 Big Sucker Air Cleaner. But someone brought up a concern I never really thought about as this is my first Harely. I'll try my best to explain what happens.
When I turn the key to ON and hit the Run Button. I hear the fuel pump run and when I hit the start button. The motor turns over for a second then stops for a quick second then turns back over fast and starts right up. I didn't think of it as an issue till couple buddy's said somthing about it. They said maybe a battery going bad? Bad spot in starter? I can let bike sit all week or it can be cold or engine be hot and it always starts like that. No issues with dimming lights or battery dead after sitting for a week.
Should I be concerned? Or is this the way the 1200 turns over.
Old 06-27-2016, 09:09 PM
hstrawn's Avatar
hstrawn
hstrawn is offline
Originally Posted by Steven Carr
Hi!
Nope......Yup......(sounds just like my '14 1200c)
Old 06-27-2016, 09:19 PM
LovelaceJR's Avatar
LovelaceJR
LovelaceJR is offline
Nope. Yup and 2007 and 2009 Heritage Softails, too.
Old 06-27-2016, 11:25 PM
elfnyc's Avatar
elfnyc
elfnyc is offline
ride it like ya stole it and welcome
Old 06-28-2016, 12:33 AM
hscic's Avatar
hscic
hscic is offline
Welcome to the forum.
No big concern...common. Not knowing what kind of battery you have...it could be a lower CCA battery.
My bike did that until I changed the battery to a 16 cell Lithium with 480 CCA...and my other battery was still good. The Lithium battery is good for everyday use up to 1600cc. Bike starts right up now with no hesitation.
http://dkcustomproducts.com/Lithium-...DK-AG-16CL.htm
Old 06-28-2016, 12:42 AM
Iarecobra's Avatar
Iarecobra
Iarecobra is offline
My two cents. Keep it on a battery tender.
Old 06-28-2016, 06:04 AM
stereoguy's Avatar
stereoguy
stereoguy is offline
Upgrade your battery cables and next time you need a new battery increase the CCA. Both battery and cables are bare minimum stock for the 1200. 883's no issue.
To be safe, check your cables, here is what I found.
https://www.hdforums.com/forum/gener...ry-cables.html
Old 06-28-2016, 06:07 AM
RKZen's Avatar
RKZen
RKZen is online now
Received 1,499 Likes on 1,071 Posts
Welcome from NC and to HDF.
If it's the OEM battery, this is normal as others have said. The CCA is usually 200, but a higher CCA battery will not have that hesitation.
Old 06-28-2016, 07:06 AM
S.t.r.a.n.g.e.r's Avatar
S.t.r.a.n.g.e.r
S.t.r.a.n.g.e.r is offline
Personal experience with (2) 1200 Sportsters in (2) years...both had same "hesitation" as described...
In BOTH cases, battery eventually failed and had to be replaced.
One of them stranded me at lunch time on a work day, the other just didn't make it through the night!
The hesitation was a sign of things to come.
There is NO hesitation with the new battery.
Now, start up is IMMEDIATE, almost violent in its abruptness and sounds great.
Dustinthewind2
Electrical/Lighting/Alarm
09-06-2018 10:43 PM
potshot
08-25-2017 09:20 AM
bstephens8
Engine Mechanical Topics
08-23-2015 09:16 AM
1forrest1
04-14-2013 04:52 PM
chopmafia777
09-21-2009 09:29 AM
Quick Reply: Do I have a Starter or Battery issue
