Drive belt tension
The reality in my experience is that other things happen, such as fitting a new tyre, new brake pads, etc. Actually adjusting the belt is not often, more likely a case of setting tension after maintenance that involved removing the wheel.
Received 2,189 Likes
Mine is at 18k+... looks great. That worn chrome chipping /will eventually destroy the belt from the inside. Plan for a new pulley/belt.
When the hard chrome goes, that's what happens. Doubt you will make it cross-country. I stay local, so I'm driving it till I have I have to call son for a trailer tow. Mine looks good compared to yours. You must grind gravel if you did that in 10K..
Figured as much. Between service checks and replacement of rear tire I think I could go forever without having to adjust myself but it's good to know it's still in spec. I might get one of those 10LB tools.
