New 07 Nightster Owner
I just picked up a 2007 Nightster that is in need of some love and attention. It is the all black paint scheme and has low miles. The previous owner seemed to not take care of the bike. It needs a Paint Correction done, there are rust spots on the chrome and mirror stalks, and it is giving me the P0652 DTC. When I showed up to look at the bike it needed to be jumped. When I got it home the battery was DEAD. I put it on the Smart Charger and it now starts up without being jumped. The charger showed the battery as good, however it looks like the battery is the one it rolled off the production line with. I went out riding around the house and the battery light along with the engine light would come on together for a minute then go away. It did this a few times. I got back to the house, shut off the bike, gave it a minute, then started it back up. I am treating the bike as never having had servicing and everything being original. I am running some Seafoam in the gas and oil before I do a change. So I have some work to do before it is ready for some road trips. The plan is a new battery, voltage regulator, plugs, coils, wires, oil change, soap, wax, and elbow grease.
Do I seem to be on the right track as far as the approach to getting this thing back to its former glory?
I am hoping to have a V&H FuelPak within the next week in preparation for a new exhaust.
Received 2,189 Likes
https://www.amazon.com/Homax-Product...000+steel+wool
and
turtle wax chrome polish/rust remover
https://www.amazon.com/Turtle-Wax-T-.../dp/B0009JKGJC
good as new
deadrubberboy (09-21-2016)
I am putting miles on in my neighborhood before I change the oil to circulate the Seafoam. All the fluids are getting changed.
I am trying to find 883 Iron Rims to put new tires on.
Buy an AGM type battery and install it. If the bike startsa and runs then you can check the charging circuit, using the Stickies in the Tech Electrical section. There is no need to change stuff if it works fine! The most likely failure, after the battery, is the regulator, but if your current one works there is no need to change it. Keep the new one for a rainy day.
Good news and bad to report.
The good is that I got the voltage regulator, plugs, and exhaust changed. The Magnaflow Legacy Series sounds great. The bike fires up easier and idles smoother.
The bad, **** me! The T30 bolt for the rear brake control snapped off.
I love the sound of the Magnaflow! It is not much louder. The plugs looked rough. The valves looked like they need some Seafoam ran across them.
I rode the bike around the neighborhood and put about five miles on it. I did not run it hard due to the rear brake lever. No Battery or CEL, I suspect the issue was the Voltage Regulator. It looked like hell. I found this to hopefully fix my issue http://www.cruisercustomizing.com/bi...part/BC-056285.
