How many miles are the sportser 883 good for?
Received 2,189 Likes
Mine...I replaced the 883 with the NHRA 1250 kit at 64,883 miles. The inside of the engine looked like it had just rolled off the factory floor. I still have it carefully packed away in my garage. I wouldn't hesitate to put the 883 engine back in and run it another 65,000 miles.
An H-D 1200 conversion simply turns a stock 883 into a stock 1200, costs a lot of money, includes lots of parts (cylinders and heads, etc) and gives relatively little improvement in performance. There are SE stage kits which are better value for money and also tune the engine, for better non-stock performance.
Hope that helps a little!
There is more than one answer to that!
The 1200 conversion increases the torque to 70 Ft Lbs.
This is a 40 percent increase in Torque.
You will find the same percentage in HP gain.
If you also increase the compression (1250), you will notice an extra performance boost.
Tuning is very important, but regardless, you will feel the difference.
40 percent more Torque is significant.
ussoldier1984, let us know which way you go, if you decide to do a conversion.
There are many different kits and there are many different shops.
Choose carefully and you will be rewarded nicely.
If you are happy with the 883, there are benefits to being happy.
There are benefits to increasing the compression. Many consider the benefits, then they get the notion it is essential to being happy with their conversion. There is always the quest for more power, hence the Milwaukee eight.
It is often cheaper to sell what you have and move up to the next level.
But, if you have to rebuild, then invest wisely.
Others find the 883 quite adequate.
