Dyna Beads
Old 09-28-2016, 06:24 PM
Tileman2692's Avatar
Tileman2692
Tileman2692 is offline
Default Dyna Beads
whats with these, you add them to your tire for balancing????
Old 09-28-2016, 06:43 PM
Cobra1's Avatar
Cobra1
Cobra1 is offline
Received 1,289 Likes on 523 Posts
Many threads that discuss them. I use them and love the smooth ride.
Old 09-29-2016, 06:16 AM
fissco1234's Avatar
fissco1234
fissco1234 is offline
I've been using them for the last 10k miles front and rear, very satisfied. I just wish I had a better understanding of how they work, but the information is out there if I took the time to read it.
Old 09-29-2016, 06:42 AM
Mr_Taipan's Avatar
Mr_Taipan
Mr_Taipan is offline
The following 2 users liked this post by Mr_Taipan:
JayTee2015 (09-29-2016), Ratwerke (09-30-2016)
Old 09-29-2016, 07:00 AM
MURPHCC1's Avatar
MURPHCC1
MURPHCC1 is offline
Received 2,784 Likes on 1,356 Posts
Had them in my touring tires for over 25k miles so far.......they work!
Old 09-29-2016, 07:09 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,510 Likes on 3,769 Posts
They do not balance. They may dampen but if they do that, the tire would have been fine without them. They use to throw bags in truck tires. Look around. The pros that travel fast out west now have balance weight (hooked on) That is the only way you can truly balance a wheel. If it's wide (most Harley's are now), it actually needs to be balanced dynamically which means spinning with electronic sensors that show two locations so they can balance at angles and different areas on both side.
Old 09-29-2016, 07:23 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Dyna Beads kick ***. They made a big difference when I switched to them.....
Old 09-29-2016, 07:27 AM
Tileman2692
Cool thank you
Old 09-29-2016, 07:35 AM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
Old 09-29-2016, 07:36 AM
JayTee2015's Avatar
JayTee2015
JayTee2015 is offline
Originally Posted by Mr_Taipan
Wow. .. that's pretty convincing. .. . and they would be reusable for a tire change.
Quick Reply: Dyna Beads
