Rear brake rotors and stuff
So, I'm in the process of figuring out what the hell to do.
Absolutely fed up with the squeal from my rear brakes, so I'm running a warranty ticket through to get me some store credit...
Tell me, link me, whatever, what aftermarket rear rotor will fit with the stock caliper setup. I know it's a shot in the dark and few will know or have an idea, I'm about five more catalog flips away from just calling EBC and asking them. So of course I figured I'd ask around first
Why do you think it's the rotor. Squeal is normally related to brake pads. Perhaps pads and caliper need to be cleaned.
Check this thread...almost same title
https://www.hdforums.com/forum/sport...ighlight=Hscic
Delboy garage also has some good vids on brakes
https://video.search.yahoo.com/yhs/s...&hsimp=yhs-004
If you are asking about rotor replacement, please let us know.
Received 2,189 Likes
i've never had a single issue getting pads. between my 3 bikes i have bought 9 sets of lyndall pads.
i swear by ebc rotors for the rear. you can just feel the quality.
ebc goodness:
a. sporty https://www.hdforums.com/forum/sport...l#post14852472
b. wide glide 1 https://www.hdforums.com/forum/dyna-...l#post14771433
c. wide glide 2 https://www.hdforums.com/forum/dyna-...l#post15484216
They have an excellent reputation around HDF, but when they run out of stock it can take them months to restock. I wanted three rotors and matching pads and gave up after a few months, as they had no stock and no info on when they could supply. As well as a stock problem they also have a near zero comms problem! That becomes a particular problem when their special rotors need special pads.
Received 1,502 Likes
I just did front and rear Lyndall gold pads on my 05 883c and it made a huge difference in stopping power. I did also add SS brakelines, new fluid, and a rear master brake cylinder rebuild so those things probally help too. I've always heard great things about all the Lyndall pads for our sporty's so thats why I went with them.
I've heard that the rear caliper and pads can give squeeling noise if the caliper isnt locked into the clip on the swing arm correctly and the caliper bolt doesnt line up correctly and allow the caliper to be in the proper position and allow the caliper to work properly. I've heard that pulling the caliper and re-installing it correctly can help remedy the issue.
Good luck.
Good luck.
