Will 2016 iron 883 mags fit my 07 nightster?
Old 09-29-2016, 10:48 PM
209militia's Avatar
209militia
209militia is offline
6th Gear
Default Will 2016 iron 883 mags fit my 07 nightster?
Will the new silver/black 9 spoke iron 883 mags fit on my 2007 nightster?
Old 09-29-2016, 10:57 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
yes. will need to adjust spacers and bearings.
front axle size changed in 2008.
"2008 front axle enlarged from 3/4 inch to 25 mm, rear axle decreased from 1 inch (25.4 mm) to 25 mm"
Old 09-29-2016, 11:06 PM
209militia's Avatar
209militia
6th Gear
Thank you.
Old 09-30-2016, 07:59 AM
209militia's Avatar
209militia
6th Gear
I found a spacer / wheel bearing kit that I think will work for the front. I'm having a hard time finding out how to mount the rear wheel. Do I need a smaller axle? Will I need to machine out wheel?
Old 09-30-2016, 08:29 AM
209militia's Avatar
209militia
6th Gear
This is the front adapters I found. Still not sure about the rear wheel tho. http://vulcanworks.net/store/Wheel-B...mm-to-3-4.html
Old 09-30-2016, 09:21 AM
cvaria's Avatar
cvaria
cvaria is offline
Swspping tbe bearings and maybe the sleeves.
I have a similar project going with the same exact issues (same year bike/specs) you are dealling with plus more, a mid glide conversion.
https://www.hdforums.com/forum/sportster-models/1121182-2016-roadster-info-finally-posting-in-dealer-systems-wheel-p-n.html
You'll see the same adapters in this thread.
It has just been sidelined by an accident and rebuild of another bike with, now, constant wtf moments and it just stole 2 grand from me... evil bike.
I will resume the sporty project as soon as i wrap the current phase of my other deal.
All i need for the sporty project is a 48 or custom axle. 2008+ roadster sliders, neck bearings, spacers, wheel bearings and tires... maybe a rear axle.
So i will be following your progress as well. Reach out to multihdrdr and see if he can help you.
Old 09-30-2016, 10:26 AM
cHarley's Avatar
cHarley
cHarley is offline
Just to be clear and keep it simple, you want to adapt the new wheels to use your existing axles.
Old 09-30-2016, 10:29 AM
209militia's Avatar
209militia
6th Gear
yeah that would be ideal
Old 09-30-2016, 10:41 AM
cHarley's Avatar
cHarley
cHarley is offline
It's the only way unless you plan on replacing the front forks. The fork leg axle holes are sized for your existing axle, same goes for the rear.
Old 09-30-2016, 10:49 AM
209militia's Avatar
209militia
6th Gear
No fork swap. Want to keep that stock.
Quick Reply: Will 2016 iron 883 mags fit my 07 nightster?
