Lower shock bolt looks alittle bent
Old 12-07-2016, 11:00 PM
Winweg12's Avatar
Winweg12
Winweg12 is offline
Originally Posted by gar187er
Its like 30 mins tops for all four bolts.
If you do one at a time, you dont even need to jack up the bike.
Are you sure Ill be able to get them in straight without lifting the back end up? Thats my only concern
Old 12-07-2016, 11:31 PM
Yamaharley's Avatar
Yamaharley
Yamaharley is offline
You could just use an automotive style floor jack to take a little bit of the weight off of the shocks without lifting the wheels off the ground. Might be easier and that's how I usually do it.
Also, I wouldn't wait too long to put new bolts in. If it's bent it's weak and if it breaks while riding the tire will bottom out in the fender and most likely cause you to wreck it.
Old 12-08-2016, 01:33 AM
hscic's Avatar
hscic
hscic is offline
For peace of mind, replace. Never compromise your safety. Failure of any critical fasteners may result in serious injury or death. Did I scare you enough lol...don't take short cuts...you're on a motorcycle.
Easy job to replace those bolts. Be sure to torque to spec.
Old 12-08-2016, 05:37 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Thumbs up
That's my approach as well.
Old 12-08-2016, 05:55 AM
Back-n-Black's Avatar
Back-n-Black
Back-n-Black is offline
Originally Posted by Winweg12
Im just a bit lazy when its cold outside.
Come on man...It's like 50 out.
Old 12-08-2016, 06:56 AM
Dead Creek Cycles's Avatar
Dead Creek Cycles
Dead Creek Cycles is offline
Former Sponsor
Like others said, the bolts are easy to replace without completely jacking up the bike. All you need to do is support the bike under the frame with a jack to take the weight off the bolts when you replace them and they will go right in. Just do one bolt at a time.
Also, be sure to get the proper hardware. I would recommend grade 8 bolts if it was me replacing them, just for added peace of mind. Don't get the cheap stuff because that could be disastrous.
Old 12-08-2016, 08:37 AM
hexnut's Avatar
hexnut
hexnut is offline
I have been riding Harleys since 1960 and I have never seen a shock bolt break on one. It may have happened but I have never seen it. Has any one else ever seen a lower shock bolt break on a Harley??
Old 12-08-2016, 08:45 AM
hscic's Avatar
hscic
hscic is offline
I have never seen one break or come loose but you surely don't want to be the first...lol
Old 12-08-2016, 08:48 AM
Ratwerke's Avatar
Ratwerke
Ratwerke is offline
Have seen only one shock bolt break in my life, not on a Harley.
Bushing hole was egged out and flexed bolt back and forth till it gave up.
Check the bushing hole while it's out, or it will happen again.
Old 12-08-2016, 08:56 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
If I had any inclination one of my shock bolts was bent or compromised in any way; I'd replace them.
OP you may want to put a cotter pin in that rear axle nut.
Winweg12 (12-13-2016)
Quick Reply: Lower shock bolt looks alittle bent
