Lower shock bolt looks alittle bent
Old 12-07-2016, 08:02 PM
Winweg12's Avatar
Winweg12
Winweg12 is offline
Default Lower shock bolt looks alittle bent
By the looks of it, my lower rear shock bolt is a tiny bit bent. Based off the pics do you think its worth worrying about? Or is it just me being overly OCD! Thanks
Attached Thumbnails Lower shock bolt looks alittle bent-screen-shot-2016-12-07-at-7.57.17-pm.png   Lower shock bolt looks alittle bent-screen-shot-2016-12-07-at-7.58.34-pm.png   Lower shock bolt looks alittle bent-screen-shot-2016-12-07-at-7.58.50-pm.png   Lower shock bolt looks alittle bent-screen-shot-2016-12-07-at-7.59.11-pm.png
Old 12-07-2016, 08:08 PM
hexnut's Avatar
hexnut
hexnut is offline
Doesn't look bent to me. Maybe I just cant see it.
Old 12-07-2016, 08:19 PM
Winweg12's Avatar
Winweg12
Winweg12 is offline
Thanks for the reply. Hopefully its just me being too OCD
Old 12-07-2016, 08:27 PM
hexnut's Avatar
hexnut
hexnut is offline
Pull it off and put it on a straight edge if that will make you feel better. then just go ride some.
Old 12-07-2016, 08:32 PM
gar187er's Avatar
gar187er
gar187er is offline
yeah, it does look like its been holding some weight.
I would replace all the shock bolts if one is showing wear.
Old 12-07-2016, 08:33 PM
Winweg12's Avatar
Winweg12
Winweg12 is offline
Im trying to avoid pulling it off. Not that its hard Im just a bit lazy when its cold outside. As long as the group consensus is that its not to be worried about Im gunna keep on ridin.
Old 12-07-2016, 09:07 PM
Winweg12's Avatar
Winweg12
Winweg12 is offline
Just ordered new shock hardware for whenever Im feeling a bit more productive.
Old 12-07-2016, 09:55 PM
gar187er's Avatar
gar187er
gar187er is offline
Its like 30 mins tops for all four bolts.
If you do one at a time, you dont even need to jack up the bike.
Old 12-07-2016, 09:57 PM
CrackHeadBob's Avatar
CrackHeadBob
CrackHeadBob is offline
Shock bolts from the dealer are about 8 bucks. (At least at my dealer.) It you're concerned, I'd replace it.
Later!
Old 12-07-2016, 10:03 PM
Yamaharley's Avatar
Yamaharley
Yamaharley is offline
It could have been caused by hitting a big bump or pothole. If you're going to replace the one replace all of them. If one breaks while riding that could turn into a bad wreck.
Quick Reply: Lower shock bolt looks alittle bent
