Fluid capacity help
Old 01-07-2017, 06:41 AM
Hammerhead Pat's Avatar
Hammerhead Pat
Hammerhead Pat is offline
Default Fluid capacity help
Kid at work has an 03 1200 and doesn't have a clue about it. I told him I would change his fluids and go over the bike for him. Can someone help me out with the capacities? Thx from the Touring section...
Old 01-07-2017, 07:56 AM
hexnut's Avatar
hexnut
hexnut is offline
Trans and primary takes 1 quart. Engine takes 2.8 quarts. Put two quarts in the oil tank then start it for a minute then add oil till its half way on the dip stick. And if you have never done this get a manual.
Old 01-07-2017, 08:48 AM
Hammerhead Pat
Thx for response! As I stated, it's not my bike so I don't have a manual for it, that's why I was asking..
Old 01-07-2017, 10:19 AM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,640 Likes on 1,132 Posts
The transmission/primary drains from a hex plug on the bottom of the primary case, near the back of the engine. The nut and screw underneath and near the front of engine case is your primary chain tension adjuster, DO NOT mess with it! Refill through the small inspection cover on the upper outer side of primary.
There is a drain hose/plug from the oil tank, look under the bike. That's how you drain the oil, then remove filter. The engine is dry sump lubrication, little oil remains in the case, it's in the tank or in the filter. Be sure to ride the bike about 20 minutes so any oil that might have drained into the engine (through oil pump tolerances) during inactivity has chance to be pumped out and back to tank. Change oil when engine warm, obviously.
Good luck.
John
Old 01-07-2017, 11:11 AM
Hammerhead Pat
Good luck.
John
Thanks for the refresher, I used to have a sporty so it won't be a new experience for me. My 05 didn't have the small inspection cover so I had to pull the inspection cover.
Old 01-07-2017, 02:13 PM
sawka's Avatar
sawka
sawka is offline
I realize it isnt your bike so I recommend you pass this info on. Especially if he has no idea about the bike. Tell him to get a manual, they arent expensive off ebay especially for a bike that age. He will get a better idea how to work on the bike and by reading it he will soon be comfortable working on it. (Id watch him try everything the first time as my Dad did for me.) And I dont mean the owners manual, the shop manual is the one he wants. For this change itself I think you above info should get you where you need to be.
lagunatic
Ironhead
08-23-2009 02:41 PM
grdiperna
Oil Archive (no new posts)
05-29-2009 09:19 PM
rustyironhead
Ironhead
03-06-2008 06:57 AM
texfatboy
04-03-2007 02:49 AM
ZX2BY2U
09-01-2005 08:16 AM
Quick Reply: Fluid capacity help
