883 Custom gas tank swap to 3.3 - Handle bar issues?
Old 01-21-2017, 09:00 PM
flyingfrog509's Avatar
flyingfrog509
flyingfrog509 is offline
1st Gear
Default 883 Custom gas tank swap to 3.3 - Handle bar issues?
I read around on gas tank swaps and found...
"Your factory 883 Custom handlebar riser won't work with the smaller, 3.3 gallon tank because the 3.3 is taller than your factory 4.5 gallon tank."
GREAT, my wife wants a 3.3 on her 2005 Sportster 883 Custom and loves the stock handle bars and speedo.
What options are there since the 3.3 tank is going on.
1) Can a little higher riser or extender on the riser be used to clear the 3.3 tank?
2) Are there better suited handlebars that might still keep the nice stock speedo and light cluster?
3) Options, Thoughts, & Considerations
Old 01-21-2017, 09:06 PM
Oddman's Avatar
Oddman
Oddman is offline
That custom riser is a PITA. Check out this thread for an idea of another riser speedo option
https://www.hdforums.com/forum/sport...l#post15849997
A riser swap will also allow a tank lift, or tank change
Old 01-22-2017, 06:31 PM
181fsc's Avatar
181fsc
181fsc is offline
I put the deluxe tank lift on my 48, and it allows my 3.3 gal tank to be shifed back towards the seat just enough to clear my handlebars.
Old 01-22-2017, 06:35 PM
flyingfrog509
1st Gear
Does the 48 have the same handlebar riser & speedo as the 2005 custom? (speedo under the bar instead of on top of the bars)
Where does one get said tank lift? Is that a HD item or aftermarket?
Thanks
rcrane
03-17-2021 07:16 PM
hlasney
09-11-2020 01:31 PM
varnesj21
11-16-2018 03:08 PM
jbird79
07-19-2013 05:31 PM
dayhunt85
05-09-2012 07:59 AM
Quick Reply: 883 Custom gas tank swap to 3.3 - Handle bar issues?
