2005 sportster 1200 crank
Have a question for the sportster guru's.
Can you replace the piston rod bearings on the crank pin? Is this a shop job? Difficulty? What would this cost?
I have an opportunity to by an 05 xl1200 with 20,000 miles on the cheap, the case is split to replace a shift drum ($200) part and upon inspecting the rod bearings the forward piston rod has a bit of a wobble, not really up and Down play, you can kind of rock it back and forth on the pin. Did not have any tools to check play.
So I know it needs:
Shift drum
One shift fork
Gasket kit
Piston rings and hone job.
Various seals.
If it needs a crank, I would think this bike would need more than it's worth. Any input on the crank or the worth in the project would be helpful.
So I know it needs:
Shift drum
One shift fork
Gasket kit
Various seals.
With the pressed together crank (like on that 2005) it is cheaper to just replace the crank than have it rebuilt.
But side to side play is not really a factor on HD rods unless you have some CRAZY side to side. They both will rock a little, but the front is always worse because it's the knife of the knife and fork. Up and down play is what you are concerned with. There should be no motion up or down.
