honing for new pistons: tips or tricks?
Received 47,791 Likes
stock hd 1200 equipment. before $ gets spent. please explain why i am looking oversized vs std? i am way out of my depth and 100% learning. from a $ stand point, it's looking like it's makes no sense to hone vs getting new cylinders and pistons. feels like the difference would be a diff of about $100 or so.
If you get STD pistons that are "Small" for your STD bore that may be "Big" ...not good. Along with the condition of your existing bore (eg. Taper, out-of-round)
cvaria (02-18-2017)
"Dial Bore Comparator" (aka dial bore gauge) because your actually comparing two dimensions... The dimension of the piston vs. the bore
You first measure the piston and then set the gauge to "0" using that dimension. When guage is inserted in the bore you see the difference at any place in the bore ("Taper" is also checked this way)
Also turned 90° to check "out-of-round"
cvaria (02-18-2017)
cvaria (02-18-2017)
The following 2 users liked this post by multihdrdr:
cvaria (02-18-2017),
Uncle Larry (02-18-2017)
Received 2,189 Likes
so take them and have them measured first before throwing the baby out with the bath water
You can measure with your calipers to get the nominal size
cvaria (02-18-2017)
blem kit (cylinder, pistons, etc..) is 499 or maybe hammer is feeling generous... *WINK WINK*
vs
new pistons ~250.... new cylinders ? ~300? dunno shop to bring it all together ~75-90/hr
not pretty.
i can cancel the order on the pistons, again lol. i havent pulled the cylinders yet so everything is still in place. i could scratch the piston deal altogether but, it seems like it would be a waste of the new se cnc ported heads.
man up moment. plenty to ponder. i'm in no rush.
slvrscoobie (02-27-2017)
