honing for new pistons: tips or tricks?
#51
Dyna Low Rider dual-disc 49mm front fork setup (trees/forks)
Why dont I use a Roadster inverted front end? Cause then it'd
look like a Roadster...
T.(gots to be different)
#52
What did you learn? I would really would have been surprised if "out of spec". After all you only had 16k with no issues.
Did you watch them measure your pistons and then use the dial bore gauge? What did they say the piston-to-cylinder clearance and the taper (if any) was ?
What about the Rings? Using new ones? Got feeler gauges to check end gap?
So, do they let the customers change their own tires at "The Shop"
#53
Received 2,189 Likes
"Learning" and "Practice"...that's right ..."Exposure" (understand that your scratching the surface )
[B]So, do they let the customers change their own tires at "The Shop"
he pulled me back into his work area and he walked me through everything he did. explained why all was well with the jugs and pistons i bought him, most of it went right over my head. i heard "use cast iron rings" and "avoid kb pistons", he then told me to go replace the studs as cheap insurance.
i know there is easy the hammer package way but, i'm learning more this way. i've had to hush my inner bi*** several times. come 110 time. i'll probably ask %10 less questions. i'm already considering se-585s for the dyna in the mean time.
#54
https://www.hdforums.com/forum/dyna-...l#post15346709
black (45500273) or chrome (45500267).
i think the low rider rake is in the neck but, i could be wrong.
#56
cvaria (02-27-2017)
#58
#59
#60
Received 47,790 Likes
Hello and welcome,
Your question has spurred many responses from the "experts", my take is more old school. Cross hatching is over rated but try for a 45 deg angle anyway.
Best to get a set of 5 to 10 over pistons & rings, Hone the cylinders till the pistons just barely slide through the cylinders. Keep the whole thing very clean with brake cleaner (thanks HAMMER, read-up) be careful, the hones tend to "round" / "cone" the cylinder walls so you want to hone the center more than the top and bottom of the travel area.
Clean everything well, install the tight pistons, re-assemble the engine and ride as HAMMER suggests in 3rd gear, on and off the throttle to break-in the rings, shift down and decell the engine pulling oil into the rings.
Look up HAMMER on the net and do what thy say,it works.
Remember the last Indian!
Cheers,
Cheers,
Madnss (02-27-2017)
