Wiring Question for those that know more than I do
Old 02-20-2017, 07:43 PM
tmultra's Avatar
tmultra
tmultra is offline
Originally Posted by RANGER73
He has to go BEFORE the CANBUS/TSM to get the brake signal.
I didn't on mine. Think about it. The modulator makes the turn signals work as run and brake. If the original tail light is left in place the brake and run still work as normal. So use those wires to any other auxiliary light and it will work the same way
Old 02-21-2017, 05:57 AM
BensonUK's Avatar
BensonUK
BensonUK is offline
I would say that using the colours on your light.
Black to black
Red to Orange/white
Yellow to red/yellow as that comes from the rear brake switch looking at th emanual
this was taken from the 2010 manual
Old 02-21-2017, 07:15 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,923 Likes on 3,022 Posts
Black to black
Red to Orange/white
The problem with this is he said his lights are only 3 wire not 4 like in your schematic.
Old 02-21-2017, 07:39 AM
tmultra's Avatar
tmultra
tmultra is offline
There are two running light wires. One isn't used. It's for an overseas model from what I understand
Old 02-21-2017, 04:52 PM
72 Ironhead XLH's Avatar
72 Ironhead XLH
72 Ironhead XLH is offline
Could go old school and use a flasher unit
Old 02-21-2017, 09:42 PM
DaddyKnuck's Avatar
DaddyKnuck
DaddyKnuck is offline
Received 1,658 Likes on 943 Posts
Thanks to all for your help. I'll let you know how it turns out.
Old 02-22-2017, 02:39 AM
BensonUK's Avatar
BensonUK
BensonUK is offline
I'm thinking your existing 3 wire ligths are ground / run / brake-turn, so if you tap those, you'll either blink the new light, or back feed to both lights and lose your signals. What do you have for a tail light? go to that.
Note to self...read everything
Old 02-22-2017, 11:18 PM
elfnyc's Avatar
elfnyc
elfnyc is offline
there should be a harness/plug under the seat towards the back or mooshed in there somewhere and should also have a big white tag on it
there will be a few wires in this harness maybe 8 i dont remember
cant remember the colors exact in this plug either
there is a blue wire in the plug -- this will goto the red wire of the new light
there is a red with a white stripe in the same plug--- this will goto the yellow of the new light
just use wire splice tap or t-tap splicer and u should be set
the lights ground u can ground anywhere u want
if u tap into the wires leading to the turn signals they will flash and freak out
u have to tap into the plug/harness i speak of and should work fine
Old 02-23-2017, 03:52 PM
DaddyKnuck's Avatar
DaddyKnuck
Exactly right! Thanks for your help.
Old 02-23-2017, 04:07 PM
elfnyc's Avatar
elfnyc
elfnyc is offline
get some video of it working ! my brain works sometimes lol glad to be of help
Quick Reply: Wiring Question for those that know more than I do
