Oil Leak - Worth Fixing?
Let my Sporty sit for about 4 months and she basically bled out. Leak is heaviest around the primary gasket (left side of the engine), but also directly below the front of the engine, middle (almost directly under oil filter).
Asked my local shop for their opinion and they said it's not worth tearing the engine down to fix since a 98 Sporty will "always have leaks". I drained the oil and there was only a quart of oil that came out so I would consider that a pretty serious leak...
Thoughts? The primary gasket should be easy enough to fix but my concern is the leak directly under the front of the engine - seems like it might be a rabbit hole to get to...
The following 2 users liked this post by 72 Ironhead XLH:
boston jim (02-26-2017),
Madnss (02-22-2017)
