tire rubbing rear fender
Old 02-23-2017, 04:18 PM
yosemite91's Avatar
yosemite91
yosemite91 is offline
Default tire rubbing rear fender
I have A 2003 Harley sportster 883 converted to 1200. it was stretched and lowered but now the rear fender and tire scrape. i have not changed tire sizes or anything. I was trying to figure out what solutions some of you may have. I have put a shorty fender on it and it seems to be fine but throws mud and water on my back. All input is welcome!
Old 02-23-2017, 05:37 PM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,631 Likes on 1,125 Posts
Taller shocks and/or stiffer springs. I'd go with taller shocks. A 2003 can take up to 13 inch rear shocks. My 1991 has 13.25" stock. Not sure if your frame has been modified, but we should have the same frames. 1991-2003 pretty similar except electrics.
John
Old 02-23-2017, 07:47 PM
yosemite91's Avatar
yosemite91
Default Frames
I know my frame was modified but it should be very similar if not identical in the rear. The rear suspension looks like the stock suspension that came on them. I'm wondering if I can just tighten the suspension and that will do the trick?
Old 02-24-2017, 08:16 AM
John Harper
How long are your shocks? How heavy are you? Give it a try if you have a notch left to adjust the spring preload.
John
Old 02-24-2017, 09:21 AM
yosemite91's Avatar
yosemite91
Default Need to diet
lol well I am a bit on the heavy side 6' 275lb that being said I do know it was doing it before I bought the bike because the old tire had a groove down the center showing the band. I'll have to measure the shocks in a day or two and I'll keep you posted thanks for the input
Old 02-24-2017, 09:56 AM
John Harper
Check to see if the seat bolt has been replaced and it too long. That would cut a groove in the tire.
John
Old 02-24-2017, 01:13 PM
yosemite91's Avatar
yosemite91
will do I think the whole tire was rubbing as well but I'll get my hands on the old fender in a few days and keep you updated thanks again
Old 03-04-2017, 09:14 AM
yosemite91's Avatar
yosemite91
Default Update
This is what I'm working with but I have decided to go hard rail and a solo springer seat as it's the look I was going for anyway and it will ultimately solve my fender rub issue
coco_iron883
07-27-2023 05:52 AM
hfp3030
05-16-2012 12:20 AM
jayel79
03-23-2009 09:42 PM
ishvin
09-05-2008 12:09 PM
SM49
03-24-2008 06:34 PM
Quick Reply: tire rubbing rear fender
