2005 Sporty starter problem
Old 03-29-2017, 02:36 PM
chazdo2's Avatar
chazdo2
chazdo2 is offline
Stage IV
Default 2005 Sporty starter problem
My sporty wont start. Just clicks. Cleaned all grounds and all leads. Same thing. Battery load tested fine. I jumped directly from the battery hot side to the starter post same thing. I have read it could be just the solonoid needs a cleaning? Can I remove it from the bike without removing the starter?
Old 03-29-2017, 03:04 PM
2005 XL1200C's Avatar
2005 XL1200C
2005 XL1200C is offline
I have a 05 XL1200C since the bike is just about 12 years old I accept the Idea of replacing parts , due to age and wear . sometimes a newer part may be more advanced in tech . I have learned that aftermarket thing like levers, saddle bags, ECT... are ok but when it comes to the motor genuine HD parts is the way to go.
Old 03-29-2017, 09:22 PM
heybaylor's Avatar
heybaylor
heybaylor is offline
yes you can take the side off of the solenoid and clean/replace the contacts and actuator.
no need to remove starter or the solenoid assembly
pretty easy to do and be sure to DISCO the battery b4 you start
Old 03-30-2017, 10:38 AM
72 Ironhead XLH's Avatar
72 Ironhead XLH
72 Ironhead XLH is offline
Te best way is to remove the 2 bolts and remove it and work on a bench. This way you can bench test everything before you reinstall it
Old 03-30-2017, 12:18 PM
chazdo2's Avatar
chazdo2
chazdo2 is offline
Stage IV
I pulled it cleaned it and put a known good big battery on the starter hot lead and case. same thing I guess the starter is gone..............right?
Old 03-30-2017, 04:25 PM
72 Ironhead XLH
nope, not untill you open the starter to see
Old 03-30-2017, 04:31 PM
72 Ironhead XLH
Old 03-30-2017, 04:33 PM
72 Ironhead XLH
Old 08-10-2021, 10:32 PM
aj.ontwowheels's Avatar
aj.ontwowheels
aj.ontwowheels is offline
Stage I
Default Update
I know it’s been years, but I’m in the same predicament now. Did cleaning the solenoid fix it or did you end up replacing the whole starter?
Old 08-11-2021, 07:39 AM
davekp's Avatar
davekp
davekp is offline
If it's "clicking" that's the sound of the solenoid functioning, so it is ok.
Is the battery fully charged?
Quick Reply: 2005 Sporty starter problem
