Ignition toggle install
Hey everyone. I've done some searching through the forums on here and I haven't gotten a solid answer to my issue.
I'm looking to take off my ignition and install a toggle switch, that I would hide. I ride a 2015 sportster 48. Been having alot of issues with my ignition and have had to replace it and the key is currently stuck in it again. The key goes in 3 positions. Off, accessory, and start.
How would I go about doing this? The ignition has 2 wires running to it, but I hooked a single throw toggle to the wires and got nothing. Any advice helps! Thank you.
Rubber side down
Rubber side down
Rubber side down
Rubber side down
Might want to use the advanced search feature to find other threads,
but here's a thread that will probably intrest you starting on page 9.
https://www.hdforums.com/forum/sport...-toggle-9.html
There are other threads using a FatBob ign switch, but I dont think thats
what you're wanting...
hth,
T.
Won’t work cause it’s canbus
Rubber side down
Rubber side down
