pesky battery cover clips
Old 06-27-2007, 01:19 PM
davelisa5969's Avatar
davelisa5969
davelisa5969 is offline
Default pesky battery cover clips
hi, i did review all of the old posts on those pesky battery cover clips and how to modify them so the cover does not come loose. I have the grey clips, is drilling a small hole through the clips on both ends and running a wire tie thru the holes the best method? thanks
Old 06-27-2007, 02:05 PM
dsuppa's Avatar
dsuppa
dsuppa is offline
Default RE: pesky battery cover clips
I had this problem when I first bought my 883,ended up losing the battery cover twice 2nd time was on a highway so I couldnt get it back. I went to the dealer and they warrantied(dont know if thats spelled right) the cover and replaced the clips with better ones. Since then I have had no problem with it *knock on wood*.
Old 06-27-2007, 02:10 PM
StargazerXT12's Avatar
StargazerXT12
StargazerXT12 is offline
I've not had any problems since the dealer replaced the clips on mine either. Apparently there are new clips that work better. Whatever they've done, it seems to be working on my bike.
Old 06-27-2007, 02:23 PM
04sporty's Avatar
04sporty
04sporty is offline
yes, drill small hole through clips. Thenput cable strap through it. Cut off extra length.
Old 06-27-2007, 02:27 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
Don't let the 'new, improved' clips for the battery cover fool you.
I've seen those fail as well.
Old 06-27-2007, 03:56 PM
StargazerXT12
ORIGINAL: OldFenderGuy
Thanks. I will definately keep that in mind. I appreciate the info.
Old 06-27-2007, 04:10 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
Yep, I had the "new, improved" clips on my bike when I totally lost the freekin cover.
And in most cases that have been reported here, the stealer hasn't covered that under warranty, including in my case. I did FINALLY get them to replace the Wing Tip Chrome accessory that was on the lost cover. But that was just because the owner of the dealership got tired of hearing about it, and me discussing it with potential customers at the dealership..
And yes, the tie wrap works very well.
Old 06-27-2007, 04:11 PM
davelisa5969
the tie wrap sounds the best, holds up pretty well?
Old 06-27-2007, 04:47 PM
LANGeek's Avatar
LANGeek
LANGeek is offline
The advantage of not having a battery cover, it won’t fall off
surazal54
02-19-2011 07:24 AM
bobbbey
05-29-2009 09:42 PM
cjm80
10-10-2008 05:38 PM
8541hog
09-03-2008 05:33 PM
freekinfreak
12-17-2006 12:09 PM
Quick Reply: pesky battery cover clips
