Getting All of the old oil out of crankcase!
RE: Getting All of the old oil out of crankcase!
OK I screwed up. Just bought my sportster used without manual, tried drainig oil through plug on bottom and let drain all day. Can`t even figure out how to getthe oil outof the oil tank. How do I drain the tank? Have I lost my prime? I`m scared to death. Please help!
ORIGINAL: tjones
Okay, has anyone figured out how to get all of the old oil out of the sportster motor? If so will you share? I hate dirty oil. The bike is a 2004 sportster.
Bored as fuuuuuudge and this one post got me thinking. Only 4 posts..... Wonder if the bike exploded on him......
Find something more important to obsess about. Leaving a little old oil in the engine will not harm a thing.
ROSC, your oil tank has a hose attached that you drain through. Mines under the battery, the hose is stopped by a plug thing on the frame (1991 Sportster). The overwhelming majority of oil is in the tank and soaked into the filter. And you probably have not lost the prime, since the tank feeds your oil pump and you have not drained it. I usually do the filter change first, then drain and replace the oil in the tank. That way only one end of the system is open at a time.
John
John
Yes. You would have to disconnect the oil return line from the oil tank and put it into a pan and then let the bike run for a bit to get the old oil out of the crankcase. Personally, I think it's more trouble than it's worth and you probably risk damaging something a lot more than just leaving the 1 quart of old oil in the engine.
Also put the new filter on before purging the system.
Yes, many Sportster have lived long lifes with a "standard" oil change.
The Savenger tool is the best answer to your original question.
FWIW...
1) Yes drain, tip bike left and right and "filler 'er up" and go.
Stay on HD recommended oil change schedule.
2) Do an oil change, drive 50 miles and do another oil change...don't forget your filter.
3) Change oil every 1000 miles/ filter 5000
4) Combo of 2 then 3 above.
I'd think that # 4 above would accomplish you to have one clean oil system.
FWIW...
Pull the plug wires and turn the engine over until the oil pressure light goes out.
Put the plug wires back on and start her up, do not rev her hard for a minute or two. Everything should be fine.
We start newly built Harley motors all the time with nothing but assembly lube on the bearings. Our motors have bearings on the crank and not just babbitts like a car, that require pressure from the oil to almost float the journals.
