Wondering about a hitch receiver m/c carrier
Any feedback, negative and positive, on the use of a motorcycle carrier that uses a trailer hitch receiver, for a XL-1200L. The bike has a "running weight" of 575 lbs, with the addition of a windshield, sissy bar and luggage rack it probably pushes the 600 lb. mark. My concern is the only carrier I have found, which works with a Class IV 2 inch receiver has a listed load limit of 600 lbs. Seems like, even if the idea had merit, the limit would be exceeded. I'd welcome thoughts on the idea, good or bad. Seems like a viable alternative to a trailer or hauling the bike in the truck bed. I'd be using a 1999 Ford Ranger if that comes into the equation. Anyone?
RE: Wondering about a hitch receiver m/c carrier
Those carriers are pretty much intended for lighter weight sport / dirt bikes. Not only does the Sporty exceed the hitch load capacity the down force on the hitch would far exceed the weight of the bike every time you hit a bump in the road. I would look at Plan B.
