battery ??
battery ??
last week i leftthe key in the on position battery DEAD i jumped and let it run for as long as possible about 30 minutes because i live at fort irwin in the mojave (110 degrees)...being in the army i don't have much free time so i just got a chance to ride today it still won't start w/o jumping it ...how long does it need to run toget a good charge????could it be something else??
p.s new battery o5 1200 custom
[IMG]local://upfiles/19758/5527AB5C92CB49C689B4F26D879B9178.jpg[/IMG]
[IMG]local://upfiles/19758/52AF2AF538A4415695B380B8D8F5D5D3.jpg[/IMG]
RE: battery ??
When a battery is charged or discharged, this initially affects only the reacting chemicals, which are at the interface between the electrodes and the electrolyte. With time, these chemicals at the interface, which we will call an "interface charge", spread by diffusion throughout the volume of the active material.
If a battery has been completely discharged (e.g. the car lights were left on overnight) and next is given a fast charge for only a few minutes, then during the short charging time it develops only a charge near the interface. After a few hours this interface charge will spread to the volume of the electrode and electrolyte, leading to an interface charge so low that it may be insufficient to start the car.[2]
On the other hand, if the battery is given a slow charge, which takes longer, then the battery will become more fully charged, since then the interface charge has time to redistribute to the volume of the electrodes and electrolyte, and yet is replenished by the charger.
RE: battery ??
Done that to mine not to long ago used the trickle charge but i talked to the dealer and they told me if it would start i could ride it and it would take about an hour to fully recharge it. so if you don't have the time to ride it any auto parts store you can get the trickle chargers stating around 20 and working there way up depend on what you are willing to spend and all the extra bells and whistles the basic worked for me.
RE: battery ??
thanks man i have today off so i plan on riding all day ....that should do it
[IMG]local://upfiles/19758/15A4FFE640C44565A430D4DE1FFD4A0E.jpg[/IMG]
[IMG]local://upfiles/19758/A7EBCBF66F4B4965A4917745D978CA51.jpg[/IMG]
[IMG]local://upfiles/19758/417862C1EC2447808E4E2DF1D20FCA3F.jpg[/IMG]
RE: battery ??
i would pick up one of the cheap chargers mine was only 25 at advance auto and it comes with a plug that you put on the battery terminals and you can route it so all you have to do is plug into the charger when ever you want to with out have to take seat off or battery out will come in very handy this winter any way. good luck
RE: battery ??
Best on the market:
Automatic 12V 1.5 Amp Battery Charger
[ul][*]Fully automatic 5 stage cycle for efficient charging[*]28-day charge recycle re-evaluates battery condition for long-term storage[*]Up to 16 volts for recovery of sulfated batteries[*]Error proof operation[*]Reverse polarity protection[*]3 year limited warranty[/ul]
