Wide Glide Mini Apes on 883L
Old 01-09-2008, 07:57 AM
Jughugger's Avatar
Jughugger
Jughugger is offline
Default Wide Glide Mini Apes on 883L
Looking to install a set of stock mini apes, cables, and risers off of my o6 Wide Glide to my wife's 05 883L. Will the Wide Glide cables, brake line and risers fit on the 883?
I was told at the stealer that the Wide Glide cables would not fit, (May be trying to sell me something I don't need). Also, would I need a wiring extension?
The Sporty is presently configured with the stock buckhorn bars.
Thanks for any info.
Old 01-09-2008, 02:42 PM
BHEBE55's Avatar
BHEBE55
BHEBE55 is offline
Default RE: Wide Glide Mini Apes on 883L
I think that would be cool as long as you dont put no big ape hangers on that bad *** looking dyna.
Old 01-09-2008, 05:28 PM
Jughugger's Avatar
Jughugger
Well,
The thought has DEFINETLY crossed my mind! Was thinking maybe some 18's or 20's...............Naw, some 14's or 16's would look just about perfect!
Some black minis and a set of V&H black shortshots would look sweet on your ride.......
Old 01-09-2008, 07:18 PM
Werbeck's Avatar
Werbeck
Werbeck is offline
The apes on my Nightster came from a Wideglide. The dealer had to order new cables to fit but the existing Nightster wiring harness fit OK and did not have to be replaced. I imagine the 883L would be the same.
[IMG]local://upfiles/19046/7C39F525205B4411AA785E401F949FB9.jpg[/IMG]
Old 01-10-2008, 04:28 AM
Jughugger's Avatar
Jughugger
ORIGINAL: Werbeck
Werbeck,
Thanks for the feedback.
I have the stock cables, 1 1/4 mini apes, risers, and brake line from my wideglide sitting in a box, from when I converted to Street Slammers. Was hoping someone would chime in as to these parts fitting the 883L. Would save me a bunch of money from purchasing new cables and brake parts. Good to know I may have enough wiring harness in the Sporty for the added height.
Old 01-11-2008, 05:29 AM
Jughugger's Avatar
Jughugger
Does anyone know if I can swap a set of 06 WideGlide mini apes, risers and cables over to an 05 883L? Will it work?
Old 01-11-2008, 07:58 AM
capttawes's Avatar
capttawes
capttawes is offline
I can't see any reason why it would not work excpet for maybe the length of the clutch cable and possibly needing to ext. the wire harness. IF you already have the stuff why not mock it up and see? I'm running wideglide/street bob minis on mine but with 3" round top risers and I replaced all cables except thottle/ide and ext. the wires.
Old 01-11-2008, 10:15 AM
Jughugger's Avatar
Jughugger
ORIGINAL: capttawes
capttawes,
Thanks for the info. You bike has the look I'm trying to achieve on my wife's sporty.
Could you tell me what length clutch and brake cables you used in case the Dyna cables are too long?
How long of wiring extension did you need? Thanks.
Old 01-11-2008, 10:37 AM
capttawes's Avatar
capttawes
Hey Jug,
I used a 44" russell braided SS brake line and a 59" drag spec. clutch cable. The clutch cable could be a bit longer depending upon how you route it (example through the trees) but fit fine mounting the way the stock one is. I soldered in about 6" maybe more wiring extension (get the cheap ext. kit from JP or Dennis kirk to simplify things). All this works fine with my 3" risers so assumming your stock are 1-2" risers means it will work fine. There is a rear view shot in my gallery so you can gauge the hgt with my bars on 3" risers. By the way, I ran my switch wires internal so this accounts for a little more lenght on the wire ext. I also re-routed the stock throttle/idle cables outside the trees for the time being vs. buying new ones (been that way for 10k miles) but plan to change them out for some 36-38" braided for better fit later.
Good luck & let me know if I can help with any more info.
Old 01-11-2008, 10:43 AM
Jughugger's Avatar
Jughugger
capttawes,
Thank you sir! That is the info I was looking for. Will browse your photos shortly.
SPCJ
05-17-2016 10:19 AM
WideGlideRide011
08-09-2012 08:58 PM
John3
07-04-2010 01:31 PM
Huebie
08-31-2007 04:47 PM
ak05fxst
04-24-2006 03:52 PM
Quick Reply: Wide Glide Mini Apes on 883L
