Battery tender pig tail finally connected!!
Over the last 2 weeks there was a thread going on about the difficulty of getting to the neg. post of the battery to attach the neg. wire of the tender pigtail, and how it was easier & just as good to connect the neg. wire to the engine block where the battery neg. pole is grounded. Well, for me the block idea was out. I couldn't get my fat fist, or a wrench in that small area. So, I decided to at least try removing the battery so as to connect the pigtail directly to it. Well, the battery did came out, & getting it to do so wasn't such a big deal. I had already removed the seat, so before I tried to pull out the battery, I gently raised the wad of electrical cables that run across the top of the battery to the ignition module, & pulled on the battery at the same time, and easy as pie it slid right out. Getting a wrench on the neg. pole was a little tough, but it was do-able. Total time spent was approx. 45 minutes, from beginning to end, including putting my tools away, just as my dad taught me way back when the world was flat.
RE: Battery tender pig tail finally connected!!
ORIGINAL: pab
