Headlight Change on Nightster
RE: Headlight Change on Nightster
I'm not sure how different the Nightster is from the older Sportsters.They pretty much look the same throughout the years.I have a 1990 XL1200 and I've looked into this for a while now.That top cover is actually the mount.As far as I know there is no way to remove or change it without fabricating something and even then it would be difficult because you would have to use the same light because ALL your wiring is routed through your headlight,at least I think it stillis on the Nightster.You would have to bypass the headlight with the wiring and fabricate some kind of bottom mount for a new light.Definately opening up a can of worms.Mine has been bothering me for years although I've learned to live with it.....................for now
[IMG]local://upfiles/36280/46DB38B088C749D6956E59C5F1C1E48A.jpg[/IMG]
ORIGINAL: capttawes
All you need to do is buy a new bottom mount light, ditch the visor mount setup and drill your lower tree to bolt the new light up to.
I fabricated my own, here is a pic,if you like itI will make one for you
yes, I'm talking about the visor mount...anyone have a link to a bottom mount light assembly
Thanks
[IMG]local://upfiles/45349/774DA3B2DC46478BBE49CDA69A30B28F.jpg[/IMG]
Thanks
ORIGINAL: MJStephens
Hey TX, where did you get your turn signal relocation kit? I'm gonna get one for mine and I'm just trying to see what options I have.
Thanks
Thanks
