3 or 4 degree raked front ends
Old 01-24-2008, 03:24 PM
txoval's Avatar
txoval
txoval is offline
Default 3 or 4 degree raked front ends
I did a search and came up with a couple of hits and none had pictures
Does anyone have a picture of a Sportster with a 3 or 4 degree raked tripe tree?
Old 01-24-2008, 05:09 PM
taggiascoz's Avatar
taggiascoz
taggiascoz is offline
Default RE: 3 or 4 degree raked front ends
mine is 6° raked trees
Old 01-24-2008, 05:10 PM
Biker Trash's Avatar
Biker Trash
Biker Trash is offline
taggiascoz has 5 or 6 degree trees on his. Take a look in his photo album. Not sure if I'd even notice 3 or 4 degrees as 5 degrees is still pretty subtle.
edit: Looks like he was posting at the same time as I was.
Old 01-24-2008, 05:20 PM
taggiascoz's Avatar
taggiascoz
you were faster than me biker trash, nice of you to remember
Old 01-24-2008, 05:34 PM
txoval's Avatar
txoval
txoval is offline
Thank you for the replies, I see what you mean Biker Trash, 6 degrees looks good but 4 would be hard to notice
Old 01-24-2008, 05:38 PM
mrb302's Avatar
mrb302
mrb302 is offline
ORIGINAL: taggiascoz
Okay... so 6 degrees in the trees (as opposed to neck cups).
Did you go with over length firk tubes, and if so how much longer than stock?
How did the handeling change from before and after?
Old 01-24-2008, 05:51 PM
taggiascoz's Avatar
taggiascoz
there was no need to get longer forks just because i put 11" rear shocks on, that balanced the bike, with stocks shocks (i think they are 13") 2" longer forks would have been needed, the handling is fine, i live in the mountains, lots of sharp corners in 3rd, no problems in cornering, maybe a bit more shakie at full speed and a bit less steering while getting the bike out of the garage(not a big deal) the look's improved i thought it wouldnt be noticeable but my friend noticed straight away when he saw the bike
Old 01-24-2008, 07:05 PM
PANightster's Avatar
PANightster
PANightster is offline
Tagg... I've seen your ride in previous posts and kept wondering why that thing looked so bad a$$. That is a nice looking sporty.
[IMG]local://upfiles/48111/2AE14AAE61F94A24BED063A594FFA8C8.jpg[/IMG]
Old 01-24-2008, 07:39 PM
jag1886's Avatar
jag1886
jag1886 is offline
I have Covington Cycle 3 degree trees on my 2000,I've had them on the bike since 2002. They work fine. i used stock fork tubes and 10" shocks.
[IMG]local://upfiles/43689/18D7B13271C0460D9867505525C45857.jpg[/IMG]
[IMG]local://upfiles/43689/771FB5A31B3349A081E779248E490ECB.jpg[/IMG]
Old 01-24-2008, 07:46 PM
txoval's Avatar
txoval
txoval is offline
Now I'm torn, because I can see a difference with the 3 degree rake, bike looks badass jag1886
ORIGINAL: jag1886
Quick Reply: 3 or 4 degree raked front ends
