Derby cover 2007 sportster XL 883
RE: Derby cover 2007 sportster XL 883
No, it does not. But be careful to not let that come out. It's a royal PAIN to get it back in place if you do.
Shouldn't be a problem, unless you do something stupid, like intentially pull it off to check it out. [:@]
Make sure the bike is straight up (not on kickstand) when you pull that cover off. Some of the tranny oil will leak out if the bike isn't straight up. I highly recommend some anti-sieze compound on those screws when you re-install. You'll thank me for that someday.
hab-
Not too sure what exactly you are doing but....
Last weekend pulled the cover on the G/F's SuperGlideto put her new "bling-bling" cover on. Found out the OEM has a oring, and the "bling-bling" cover takes a solid foam gasket. Not sure if the XL's are the same or not. Worth looking into to save a trip to the stealer.
Also, if ya do pull the o-ring out as Sporty said not to do, I found a very small amount of axle grease will hold it in place until secured.
Good Luck!!!!
oh yeah- FYI- I have yet to get those dang torx heads out without drilling the heads for the bolts off and replacing them with 1/4x3/4 fine thread stainless allens. Hopefully you have better luck than me!
Good Luck!!!!
ORIGINAL: joel85
Why does everyone hate the torx bolts? I have never had a problem with them on any application. Use the right size torx head and a ratchet and seems to work just dandy.
That is why guyshate them. Ace is the place!!!!!
Replaced derby cover ,removed 5 t-27 screws no problem the last one stripped
out the head I had to used a dremel to cut a slot whereas I used a flat head screw
driver to remove it what a pain its all done didn't lose any fluid I really appreciate the
input it helped me out big time.
