Sportster cough sputter and die
Old 04-19-2008, 12:53 PM
rh8234's Avatar
rh8234
rh8234 is offline
Default Sportster cough sputter and die
My girlfriends 2006 carbed 883 L has had an issue since new. Intermittent cough thru carb and engine dies when idling or trying to take off from a light. It only happens when hot (after about 20 mile ride). When the bike was new, I had it rejetted because it came lean from the factory (HD claims EPA makes them tune the new bikes lean). Didn't help much. I then installed SE intake and it ran fine all last year with no issues. Over the winter, I had stabil in the fuel tank and have recently put fresh gas in the tank. Today, it started the coughing thru carb again, but only after sitting idling at a light for a minute or 2. If I keep the RPMs at 1800 to 2000 at the light, no problems at all. I checked for intake leaks by spraying wd40 near the intake manifold and did not notice any increased RPMs so I don't suspect intake leak. I checked the vacuum at the petcock and there is plenty vacuum there at idle. Since there are no issues at high RPM, I don't suspect fuel screen. Fuel tank seems to be vented okay (no pressure in tank when I remove fuel cap and I can easily blow thru the vent line). I get the same symptoms with brand new spark plugs too, so I doube it is the plugs. Could a MAP sensor or Crank Position Sensor cause symptome like this at low RPM's?
Old 04-19-2008, 08:02 PM
jmarkle's Avatar
jmarkle
jmarkle is offline
Default RE: Sportster cough sputter and die
Happened to my 06 1200c. It was the crank position sensor. Acted exactly the same way.
Old 04-20-2008, 05:32 PM
Sail and Ride's Avatar
Sail and Ride
Sail and Ride is offline
I was going to suggest adjusting the idle mixture, but after reading the previos post...
Old 04-20-2008, 07:51 PM
Lowridin's Avatar
Lowridin
Lowridin is offline
ORIGINAL: jmarkle
Same thing happened with my girlfriends 06 1200L with only 1000 miles on it.
nickkova
04-05-2016 02:51 AM
PoliceBagging
07-22-2014 06:40 PM
250REDNECK
Exhaust System Topics
28
09-24-2011 03:47 PM
jrjones
13
08-21-2009 07:45 AM
jcknapp
02-17-2006 07:15 PM
Quick Reply: Sportster cough sputter and die
