Need Help installing a screaming eagle ignition
Old 04-20-2008, 01:36 PM
KSCruiser's Avatar
KSCruiser
KSCruiser is offline
Default RE: Need Help installing a screaming eagle ignition
ORIGINAL: jpar05nm
I have the 7000rpm module in mine. Had to take it to the dealership and have the bike and module formally introduced through their computer.
Had to do the same thing. They charged me half-hour labor rate for it.
Old 08-16-2009, 02:35 PM
slanginink's Avatar
slanginink
slanginink is offline
Stage I
Got mine to work. by following instructions. Accept I did not turn the cockeyed key off at all. use the ignition switch not the KEY< LEAVE THE KEY ON!!!!!!!!!!!!!!!!!!! until the process is complete. Note make sure you have a battery charger hand, Not a tender. Process should take 25 minutes.
Old 08-17-2009, 06:03 PM
jag1886's Avatar
jag1886
jag1886 is offline
SE 8000 RPM revlimited ignition! What exactly have you done to this race horse to need that and if you really need an 8000 RPM rev limiter why didn't you get a good one that would exually do something besides raise the rev limiter?
Just curiuos.
Old 08-17-2009, 07:06 PM
Booey424's Avatar
Booey424
Booey424 is offline
I put my Sceamin Igniton module on myself.I just fed the wires through the hole the original wires came from.Then I had to look at the plugs to get all the wires in proper order.It has worked great since.I did wrap the wires with electical tape to feed them through better
obsolete
EVO
06-03-2010 12:30 AM
obsolete
EVO
06-02-2010 09:07 PM
obsolete
EVO
06-01-2010 10:11 PM
BB4xl
EVO
21
06-03-2009 10:27 AM
Booey424
11-13-2007 01:12 AM
Quick Reply: Need Help installing a screaming eagle ignition
