Never spray painted before...help? (nightster air filter cover)
I've never really spray painted anything before...hell, I haven't painted anything before! Anyway, I baught this last night http://cgi.ebay.com/ebaymotors/ws/eB...19221&rd=1so instead of ruining my stock air filter cover I can waste this one. I want to do it flat black, I found some rustoleum automotive flat black, I'd assume that is the right stuff? How about priming or cleaning before hand though? Or techniques to spray paint? I was told I need to sand the surface before painting- well, the air filter cover is rough, is that just the type of paint they used? Will that sand off?
I'm completely lost and a total newb, so help me out please!
RE: Never spray painted before...help? (nightster air filter cover)
two coats are better the one! sand the surface, prime it, then paint it with light overlapping motion. try to hang it while you spray it... even coverage all the way around, better air flow to dry it.. I would recommend high heat paint if available.
first, do a scratch test to see if it is paint or metal.. then start with 150 and go progressively higher.I like to use wet sandpaper, which is available at any auto store. the higher you go with the sandpaper, the better the finish.. I also sand between coats. then finish off with high quality clear coat, at least 3 coats
Something just came to mind; looking at my stock cover, this seems like it could be wrinkle paint. If I'm right, I could just hopefully sand down the entire surface, make the air filter nice and flat, then clean/prime, and use flat black wrinkle paint to create the same effect. This is all new to me though so looks like I'm in for some fun.
ORIGINAL: VBCH Nightster
I painted my stock cover with Krylon matte black spray paint. Looks good.
Clean the cover real good to remove the oil/grease and dirt, and you should be OK.
ORIGINAL: brainfrz
VBCH Nightsteryou got any pictures?
In think the rough finish on the stock cover is the metal, not the paint.
