what is this?
what is this?
2008 Sportster Roadster......Lower left side of engine, the wire in the center of the picture...should this be plugged into something or be capped?....what is it?
[IMG][/IMG]
Second question.....Just did an oil and filter change and engine check.....Ignition on and oil check lamp comes on....run engine for a short period then switch off. Few seconds later turn ignition switch on and oil check light does not come on, is this normal on a sportster. If I wait a few minutes with switch off and try again, it comes back on. Does this mean that pressure remains in the engine for a short period of time after off?
Thanks.
[IMG][/IMG]
Thanks.
RE: what is this?
I just went to check that on my bike. Nope oil light comes on everytime, right away. I have discovered that the two relays inthe fuse block are very touchy. They hate getting wet and any built up corrossion makes them act stupid. Might wanna pull them and check for corrosion. A little dielectric grease would be good insurance.
RE: what is this?
From looking through the shop manual, it looks like it might be the crank position senor harness. But it shows it as connected, and I believe "inside" of the boot.
It is a little hard to see because, although your picture is "supersized", it only shows a very small area, and it is harder to see the surrounding area to compare.
But it may be the "CKP sensor harness connector".
If you have a shop manual, look at page 7-80. (Although my manual is for an '07, so your mileage may vary[&:]).
RE: what is this?
Actually, after looking some more......it looks like the CKP behind that exposed connector? Therefore ruling that idea out.
I went and looked at my bike, and all I see besides the crank sensor, is 2 other connections just above, and forward of that. Two connections fastened to the frame. Are they both plugged in on yours?
