Old 03-17-2015, 05:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
Use this thread to fix all of your bike’s needs. Learn and fix your bike for a fraction of the cost. Some topics include:
• Oil Change
• Clutch Adjustment
• Battery
• Tools need for repairs
Read full discussion below
Print Wikipost
Poor Man's Sportster Service Maintenance Guide
Old 06-18-2008, 10:34 PM
BluePotato's Avatar
BluePotato
BluePotato is offline
Default RE: Poor Man's Sportster Service Maintenance Guide
ORIGINAL: thomasf59
Some of that instruction is generic, I would never adjust my primary chain (bike running in gear)as some suggested, after following some of that advice you would be a poor man, after the F**k ups were repaired.
Didn't bother to look at the other tips,seen enough after the primary and clutch and throttle calbe instruction.
Thanks for the constructive criticism, Thomas.
If you check out my post, you'll see that I never meant for any of this to replace the service manual. It's no more than a collection of links that I have found helpful reading. I also mentioned that I'm happy to update the list. If there are better instructions out there, I'll replace the links with better ones. But, I think we could all agree that it would be a naive approach to say that there is no help in using anything but the service manual to learn maintenance.
Correct, that's why denoted each link that was not Sportster specific as (not Sportster specific)
Ha! You're right. It was a poor choice for a thread title! I should change that.
Old 02-14-2009, 09:30 PM
Ares's Avatar
Ares
Ares is offline
6th Gear
Old and dead thread...that should still be stickied!
I was just thinking today how the HD forums is one of the few forum sites I've been apart of that doesnt have simple FAQ info stickied for each model. Stuff like oil weights and quantities, lub info, service intervals, etc.
Old 02-18-2009, 12:10 PM
Terry TK's Avatar
Terry TK
Terry TK is offline
Big Kahuna HDF Member
Most of that info can be found in the Tech Secton of HDF
Old 02-21-2009, 09:08 AM
xlh11's Avatar
xlh11
xlh11 is offline
5th Gear
might not be usefull to you but for some of us who actualy work on our bike the info is much usefull. I dont knw about the primary chain our idle ajust but i read the oil change method and it seams fine to me. thnx for the info
Old 02-21-2009, 09:54 AM
lonesome wex's Avatar
lonesome wex
lonesome wex is offline
Cheers for the info which will benefit a f**king novice like me.
Old 03-16-2009, 07:45 PM
dangerousrider29's Avatar
dangerousrider29
dangerousrider29 is offline
Stage II
i have a 2009 nightster. i need the torque specifications for the rear axle nuts and the rear top and bottom shock bolts. can anyone provide me with that please??
Old 03-27-2009, 09:07 PM
Gunhunter's Avatar
Gunhunter
Gunhunter is offline
62-65 foot x pd for the axle nut.
Old 05-24-2009, 12:36 PM
Freaky Jeebus's Avatar
Freaky Jeebus
Freaky Jeebus is offline
thanks for the post it's nice for a guy like me just cutting his teeth on mybike
Old 07-30-2009, 09:21 AM
ironsteptoe78's Avatar
ironsteptoe78
ironsteptoe78 is offline
Stage I
hi every one if you can help me i need a wiring diagram for 1000cc 1978 ironhead so i can get back on the sweet road you can send it to me at phil.steptoe@sky.com thanks
Old 08-07-2009, 09:51 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
2005 xl service manual here: http://www.sendspace.com/file/h952ae
Quick Reply: Poor Man's Sportster Service Maintenance Guide
