Nightster Mini Ape Install Question.
RE: Nightster Mini Ape Install Question.
I've seen people get away with the stock cables. \\; I went with a new clutch cable from Drag Specialties and I also got a new front brake line from a Street Bob. \\; Right now my throttle/idle cables are stock and they work just fine.  \\;
ORIGINAL: MJStephens
I've seen people get away with the stock cables. \\;\\\\\\; I went with a new clutch cable from Drag Specialties and I also got a new front brake line from a Street Bob. \\;\\\\\\; Right now my throttle/idle cables are stock and they work just fine.  \\;\\\\\\;
Do you know how long the Street Bob brake line is?
ORIGINAL: Mister H
I've seen people get away with the stock cables. \\;\\\\\\;\\\\\\\\\\\\\\; I went with a new clutch cable from Drag Specialties and I also got a new front brake line from a Street Bob. \\;\\\\\\;\\\\\\\\\\\\\\; Right now my throttle/idle cables are stock and they work just fine.  \\;\\\\\\;\\\\\\\\\\\\\\;
i will vouch on what 07nightster says on the cables, i was with him when he installed his apes.....if you want to spend more money on cables, go ahead but if you want to save money then you can install the bars with no problems at all......so dont be scared to try.......
